Polaris 900 Heavy Duty Crank?
Postby QWKSLVRZ06 » December 19th, 2010, 10:53 pm
Hello, I have purchased what is supposed to be a heavy duty 900 crank for my friends 2005 Fusion. The crank fits just fine, I had to use 2009 800 crank seal as ther journal was larger. It has a large taper shaft and the drive clutch does not fit. Doeas anyone know what clutch fits or has anyone heard of this crank? I have already tried the 09 800 clutch, this does not work. There is no part number on the crank, it was bought off of ebay. The dealer is no help.
Never argue with an Idiot,they will only drag you down to their level and beat you with experience!
QWKSLVRZ06
Postby mbenoy119 » December 20th, 2010, 3:57 am
I believe you are going to need the 32mm tapered clutch from the sound of it. I know that clutch came on the 07 CFI motors. Check the part number for one of those models and that should be what you need
mbenoy119
Postby QWKSLVRZ06 » December 21st, 2010, 1:27 am
Thank you Mike, I have ordered the 07 clutch. I appreciate your input!
QWKSLVRZ06
