rusty gastank
rusty gastank
Postby mx6 » October 29th, 2002, 1:36 am
Greetings, anyone know of a good way to clean the rust out of a 67 Oly? Tank is built into the frame which sucks. Thanks in advance.
Stewart Selid
mx6
rusty gastank
Postby maxiracer » October 29th, 2002, 8:13 am
Try using the Works toilet bowl cleaner. It works wonders on rusty tanks. There should be a drain screw on the bottom of the bellypan. Make sure you can get it loose to drain the bowl cleaner out or just tip the sled over to drain out the filler. Flush the tank with clean gas to purge the toilet cleaner out and you should be ready to rock and roll.
[b]Bevra Vintage Ice Oval Racing. Old School rules...[/b]
maxiracer
rusty gastank
Postby mx6 » October 30th, 2002, 8:10 am
Thanks for the info, is works bowl cleaner the stuff that comes in a qt. bottle used to clean the holes under the rim on a toilet etc.?How much do you need and how long do you swish it around? Thanks.
Stewart Selid
mx6
rusty gastank
Postby sledwrench » November 5th, 2002, 12:45 am
Try going to your local auto parts and pick up a quart of fuel tank liner. Its a stinky red liquid you pour in, roll around as to coat all sides, and pour out. Its permanent and lasts. Ive used it on motorcycles, sleds even diesel equipment. What you pour out you can reuse. good luck
sledwrench
