Wrist pin removal
Wrist pin removal
Postby J_ROK » January 25th, 2006, 9:19 am
I'm having a problem removing a wrist pin from a damaged piston.Removed both jugs. The one that wasn't damaged the pin moves freely but the other one will not budge is there a special tool i could get for this? I tried a c clamp didn't work. Its still attached to cam shaft dont want to take lower unit apart. The retaining clips are removed
J_ROK
Wrist pin removal
Postby northern_sled_freak_69 » January 26th, 2006, 5:06 am
yes there is a special tool for this but u could be lookin at a few bucks for it my suggestion if u have a heat gun heat the damage piston it should come out with no hammering.. and may i ask why the piston is damaged
Wrist pin removal
Postby cosmic muffin » January 26th, 2006, 6:09 am
Good Question NSF69.And thanks for thoughts on the oil.. I found a great web with pictures on piston failure.Even as a retired Mech. I learned a thing.
http://www.mztech.fsnet.co.uk/workshop/wrk_piston.html
C/M
cosmic muffin
Wrist pin removal
Postby northern_sled_freak_69 » January 26th, 2006, 7:30 am
your welcome
Wrist pin removal
Postby kenlacy » January 26th, 2006, 7:50 am
A wooden dowl and a mallet work well for me.
Then I thought...
Chit, I could win this!
kenlacy
Wrist pin removal
Postby northern_sled_freak_69 » January 26th, 2006, 7:56 am
see with that stuff you wanna be discouraged from using blunt force for fact that u may nock the crank outta wack
Wrist pin removal
Postby kenlacy » January 26th, 2006, 8:55 am
Obviously you want to be careful - small hits - but with a mallet (I am meaning rubber)and a wood dowel there is a lot of forgiveness. I guess you have to use common sense - I just assume eveeryone has that and they sometimes don't.
A deep socket just a hair smaller than the pin works good too.
Then I thought...
kenlacy
Wrist pin removal
Postby northern_sled_freak_69 » January 26th, 2006, 9:33 am
[quote=kenlacy]Obviously you want to be careful - small hits - but with a mallet (I am meaning rubber)and a wood dowel there is a lot of forgiveness. I guess you have to use common sense - I just assume eveeryone has that and they sometimes don't.
A deep socket just a hair smaller than the pin works good too.[/quote]are you saying i have no commen sence
Wrist pin removal
Postby J_ROK » January 26th, 2006, 9:47 am
I got the sled for nothing it sat for a couple of years. It started up after a few pulls. didnt seem to respond well to the throttle so checked compression one cylinder held 96# the other 30# so decided to do a rebuild. The boots from the damaged side had a hole at the bottom of it (between carb and jug) the old owner said he had to rebuild carbs every year so i'm guessing he was trying to compensate for the extra air flow and therfore damaged the piston and cylinder. I'm gonna rering the other one. The sled is a Artic Cat Cougar 89 500 air cooled. I picked up a new head, cylinder, piston,etc... for a steal on EBay. Thanks for the info i'll try heating it first.
Can anyone tell me the proper compression range for this model?
J_ROK
Wrist pin removal
Postby northern_sled_freak_69 » January 26th, 2006, 9:54 am
90-130 and u will be fine
