Ski doo - starts and runs then loses power and dies
Postby 1997mach1 » February 10th, 2006, 4:04 pm
I got a 1997 mach 1. I just had a new engine put in and V-Force Reeds, it ran fine for about 200 miles now when I start it it runs fine for ~10 minutes then it seems to lose power and shuts its self off. After waiting a while it will start back up and do the same thing again. Any suggestions on WTF is wrong?
1997mach1
Postby northern_sled_freak_69 » February 10th, 2006, 6:02 pm
broken reeds?
Postby jammo » February 13th, 2006, 2:02 am
Possibly vapor lock. Something is not allowing your fuel tank to vent properly
jammo
Postby snoguy14 » February 13th, 2006, 3:42 pm
Oh where to start.What do the plugs look like?Was the engine rebuilt by a pro or a shadetree.Does your fuel pump seem to pump enough fuel? Check the coil for a crack i have seen a coil get hot and discharge getting the same symptoms when the motor cools.Is the cdi failing? PLUG colour is the most important info are they wet when it stalls?Try this run the sled,wait for the failure pull the plugs if their wet i'd bet on ignition failure if they are very light check fuel delivery it could be as stated a simple problem with the vent hose,or a clogged pulse line,it could even be the wiring getting warm and grounding don't laugh i've seen all the above happen.
I'm not fast, your just slow.
snoguy14
