98 skidoo formula 3 wiring
Postby semiwrecker1 » December 28th, 2006, 3:34 pm
OK i have a 98formula 3 600 that was in a fire and i am putting it back together now i cant figure out a few things i aqm only putting in the temp and fuel gauges, not a clue what color is what for those 2 and i have no high beams i put the button and it turns off my lights i have tested both headlights and both highs and lows work but when i hook up the switch only have the low beams i have 3 wire on each light yellow with black stripe purple with green and a grey wire i have figured out that yellow and black and purple and green are the low beam but not sure about the high beams anyone have any ideas ?
semiwrecker1
Postby leo_kendall » December 29th, 2006, 5:59 am
have u tryed to look for a wiring diagram?
blast from the past, how often do u change your underwear?????:?
leo_kendall
